AW690 driver/firmware package
javadR3
Where can I find a driver/firmware package for AW690 chip. I don't see any package in website page of the chip.
But in these two posts, I see that people are using some packages.
post 1:
post 2:
Javad
AW690
weidong_sun
Dear @javadR3 ,
>>Then I guess my access is more limited than you, because I see less documents and no software
Yes, right.
So please follow my guidance for your to get more materials and support!
(1) Contact local distributor FAE(DFAE)
distributor FAE will help you register your AW693 project in NXP system.
(2) Getting NXP FAE support
AW693 is for automotive, NXP FAE can support it directly. so it means you will get support from DFAE & NXP FAE.
(3) NDA & access rights
you can also get the guidance from NXP FAE or DFAE.
Thanks!
weidong
javadR3
Dear @weidong_sun,
Thanks. Then I guess my access is more limited than you, because I see less documents and no software.
 AW693:
1- documents
2- Design files
3- software
will request access for AW693.
Javad
weidong_sun
Dear @javadR3 ,
Yes, right.
Thanks!
weidong
javadR3
Dear @weidong_sun
There are only 6 secure files for #AW693 and all of them documents(pdf), no driver/firmware package.
Javad
weidong_sun
Dear @javadR3 ,
For AW693, Access rights is the same as that of AW690.
Here is it's link:
https://www.nxp.com/products/wireless-connectivity/wi-fi-plus-bluetooth-plus-802-15-4/2x2-dual-band-...
  1. Documentations:
2. Design Files
3. Software
Firmware files are packed in driver source code, after decompressing driver code, firmware files will be found.
Thanks!
weidong
weidong_sun
Dear @javadR3 ,
See below, please!
AW690 is for automotive applications, NXP FAE is responsible for supporting it.  So you can contact local distributor FAE or local NXP FAE. recommend you contact local distributor FAE first.
(1) AW690 link
https://www.nxp.com/products/wireless-connectivity/wi-fi-plus-bluetooth-plus-802-15-4/wi-fi-6-1x1-co...
(2) How to access AW690 materials (2 steps)
-- NDA is required
you can submit a ticket via NXP web site
-- applying for access secure files
The follow the guidance to fill necessary information. after the step is done, submit it, and wait for product manager's approval.
Thanks!
weidong
javadR3
Dear @weidong_sun
I made a mistake. Actually I meant AW693 not AW690. I have already signed NDA and I can see secure files for AW690 as your shared screenshot in (1) but the point is this list is empty for AW693. Do I need to sign different NDA?
Javad
AW693
