To design the WiFi/BT RF Front-end Filter,
I want to get the Spurious emission test result data on 88W9098 based system.
In the datasheet, there's only BT spurious emission data and no WiFi data.
Where can I get the WiFi Spurious emission data on 88W9098?
Regards/I.S
I.S
Solved! Go to Solution.
As far I know we do not have wifi spurious data but you can check the test result data on the application note AN - 88Q9098-88W9098 RF Performance Report WLAN
Please check if you have access to this document
have a good day.
have a good day.
