RTIC
4,156 次查看
东升王
I am working on Vybrid platform to enable RTIC feature. When I wrote those registers, the value I read back was always zero. Even I used U-boot. For example:
I wrote : CAAM_RTIC_BASE_PTR->RWDOG = 0xffff;
              CAAM_RTIC_BASE_PTR->RTHR = 0x1;
Then the value I read back was :
              CAAM_RTIC_BASE_PTR->RWDOG = 0x0;
              CAAM_RTIC_BASE_PTR->RTHR = 0x0;
Somebody can tell me why?
Thank you
2,739 次查看
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
14 回复数
2,740 次查看
CommunityBot
Community Manager
NXP Community!
2,740 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
东升王​  did you send Rene  the information requested?
2,740 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
rendy​ FYI
2,740 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
dongshengwang​ did you get previous comment?
2,740 次查看
东升王
Hi Karinavalencia
Sorry I just got your email. Here is my code for rtic. Thanks for your
help.
Dongsheng Wang
2,740 次查看
rendy
please send me *working* example - send me the project with all headers and sources needed.
Rene
2,740 次查看
rendy
please send me a short example which demonstrates this and I will check it soon. You can use TWR-VF65GS10 sample code.
Rene
2,740 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
rendy​ do you have an update?
2,740 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
rendy​ can you share your comments?
2,740 次查看
东升王
Sure, no problem!
2,740 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ can you help to review this case?
2,740 次查看
timesyssupport
Senior Contributor II
Hello Dongsheng,
Ensure that, RTIC is not in Run-time mode before writing to those registers as they are read only while in Run-time mode. Use RSTA register to find out the state of RTIC.
Timesys Support
2,740 次查看
东升王
Yes, before I wrote these registers. I checked RSTA register. It is always zero. Actually every registers are always zero. Even I read and wrote them with U-boot.
Thank you
2,740 次查看
timesyssupport
RTIC registers are set with 0 by default.I referred VYBRIDSRM and don't have much information to share. karinavalencia Can you ask the NXP Vybrid team to comment with any other information?
Timesys Support
