Hello everyone,
I'm a new owner of a tower kit vf65gs10, and I'm trying to compile a simple MQX hello example on IAR Embedded, but I'm getting some problems to make it.
I have already compile all the libraries as mentionned in the getting started guide with IAR.
I've also installed the firmwares of Pemicro, I put the board in bootloader mode then I drag and drop the cmsis-dap file.
I don't know exactly wich file I'm supposed to put in the bootloader.
I configure IAR options as following :
- Debugger -> PEMicro
- Run to main
- Attach to running target
Then I click debug and I have several messages depending on the configurations I put but it never works :
Or sometimes this one when I try to run the example on A5 Core of m board :
But when I hit Connect that only reset my board and I still can't connect to debug.
I really don't know how to solve this, anyone can help me ?
Thank you in advance.
Ahmed
已解决! 转到解答。
Hi Ahmed,
We do not support the 3rd party IAR Embedded software. The following document contains our process for debugging MQX/Linux applications with Vybrid using DS-5:
https://linuxlink.timesys.com/docs/lab_notes_for_webgl_mcc_accelerometer_demo#Exercise-5-Debugging
Timesys Support
Thank you for your post, however please consider moving it to the right community place (e.g Vybrid Processors ) to get it visible for active members.
For details please see general advice Where to post a Discussion?
Thank you for using Freescale Community.
timesyssupport can you attend this case?
Hi Ahmed,
Timesys Support
