I am using a Vybrid VF5x, and some of the inputs that I want to sense may be slowly-changing. Therefore I would like to enable the Schmitt trigger functionality on those specific pins.
I am using the lwgpio framework. Is there a way to enable Schmitt triggers using this?
If not, what is the recommended way to enable Schmitt triggers?
Dear Ricahrd,
In Chapter 5 Input/Output Multiplexer Controller (IOMUXC), in the pad configuration tables, there is a special field, number 9 and called HYS, which selects the desired input type - 'CMOS' or 'Schmitt trigger'.
Regards, Naoum Gitnik.
