Is it possible/wise to interface my Freedom board with my PBMCUSLK project boards?
945 次查看
davehaas
We are switching our course from the M52233DEMO board to the ARM Freedom board.  Is there a convenient way to interface our Project boards, PBMCUSLK, with the Freedom or do we start the interfacing from scratch?
Dave Haas
NJIT
635 次查看
admin
Specialist II
Not directly via the MCU_PORT.  The Freescale Freedom boards outmost row follows the Arduino pin scheme which I am not sure if you can plug that into the breadboard surface.  I don't have the single row of pins to test it out.  (Double rows obviously would not work because you would be shorting two pins together.)
Are you using the NI-ELVIS board in combination with the PBMCUSLK?
~John
