The only difference between the T2080 and the T2080E CPUs is that the SEC engine is enabled on the T2080E.
See T2080 Datasheet, chapter 7.1 Part numbering nomenclature. https://www.nxp.com/webapp/Download?colCode=T2080.
Thanks for your kind reply.
One more answer please.
Does having or not having Security Engine affect performance?
Where can I find the difference between T2080 revision A and B?
Please clarify what performance you mean. If your software dosn't use SEC the performance should be the same both for "E" and non-"E" devices.
The difference between T2080 revision A and B can be found in the T2080 Errata document.
