no valid license key was found
2,646 次查看
hotashu
hello ,
I refer AN393 to install my CodeWarrior EPPC 5xx V8.7 on 64bit win7. I use evaluation licesne. however it shows no valid license key was found for this installation.
what's the possiable probelm?
Best Regards
hotas
1,159 次查看
TomasPaez
Hello Hotas,
Are you getting any specific error message ? I assume you are working with a virtual environment mention on the AN3936.
Copy the following text below on a notepad and save it as a license.dat , now look in the installation path and locate the current license.dat file. If you find it replace it, let me know if this helps you
# ( 817): CW Development Studio for Power Architecture, Professional Edition, v.8.7  (Windows host)
FEATURE WIN32_PLUGINS_GCC_Adapters metrowks 1.0 30-jun-2013 uncounted \
  8087772B90CD VENDOR_STRING="GCC Adapters Windows" HOSTID=ANY \
  ck=135
FEATURE Win32_PLUGINS_PPCCPU_COMM metrowks 1.0 30-jun-2013 uncounted \
  869820A26C68 VENDOR_STRING="EPPC CPU_COMM" HOSTID=ANY ck=24
FEATURE Win32_PLUGINS_PPCCPU_HOST metrowks 1.0 30-jun-2013 uncounted \
  F435D0135520 VENDOR_STRING="EPPC CPU_HOST" HOSTID=ANY ck=101
FEATURE Win32_PLUGINS_PPCCPU_PQ3 metrowks 1.0 30-jun-2013 uncounted \
  FB3998D7D90D VENDOR_STRING="PPC CPU PQ3 Windows" HOSTID=ANY \
  ck=180
FEATURE Win32_Plugins_Common_eLinux metrowks 2.0 30-jun-2013 \
  uncounted 7CB5B24A37DA VENDOR_STRING="Common Embedded Linux \
  Plugins" HOSTID=ANY ck=192
FEATURE Win32_Plugins_PPC_EmLinux metrowks 2.0 30-jun-2013 uncounted \
  BAEE4640BCF2 VENDOR_STRING="Embedded Linux PPC plugins" \
  HOSTID=ANY ck=146
FEATURE Win32_CWIDE_Unlimited metrowks 5.5 30-jun-2013 uncounted \
  E0A79DC27107 VENDOR_STRING="CodeWarrior IDE 4.2 or later, \
  Windows" HOSTID=ANY ck=125
FEATURE Win32_CFP_PPC metrowks 8.0 30-jun-2013 uncounted D6498FA78EAD \
  VENDOR_STRING="PPC Flash Programming" HOSTID=ANY ck=193
FEATURE WIN32_PLUGINS_COMP_PPC metrowks 8.0 30-jun-2013 uncounted \
  67CECCF2C75B VENDOR_STRING="PPC build tools" HOSTID=ANY ck=206
FEATURE WIN32_PLUGINS_DBG_PPC metrowks 8.0 30-jun-2013 uncounted \
  5E0831A5EDE7 VENDOR_STRING="EPPC - Debugger" HOSTID=ANY ck=139
FEATURE WIN32_PLUGINS_PPC metrowks 8.0 30-jun-2013 uncounted \
  3C988DEDF3AC VENDOR_STRING="EPPC Plugins" HOSTID=ANY ck=196
1,160 次查看
TomasPaez
Hello Hotas,
  ck=135
  ck=180
  HOSTID=ANY ck=146
