解決済! 解決策の投稿を見る。
Hello Stefano,
In fact you have purchased Floating License CodeWarrior suite. In contrast to nodelocked license which works only on one PC, floating license allows you to run licensed CodeWarrior development tool on any computer within a LAN network.
In order to use this license you have to configure your PC to be the licensing server. In doesn't metter that it's the same PC where you will run CodeWarrior.
Attached instructions may help you to do it.
I'd suggest you to replace THIS_HOST string within your license.dat (SERVER line) by IP address or host name of your PC.
Stanish
