CW 10.4 MCU upgrade problem
1,373件の閲覧回数
DaveB
We upgraded from 10.2 to 10.4. Using the repair option we got a 10.3 license, fine.
Ours is a disk locked floating license.
The 10.2 server line reads SERVER xxx.xxx.xxx.xxx DISK_SERIAL_NUM=3C79B2F7.
The 10.3 server line reads SERVER xxx.xxx.xxx.xxx 3C79B2F7.
Without the "DISK_SERIAL_NUM" It appears the FlexLM service believes this is a MAC address.
The FlexLM log shows...
9:15:29 (metrowks) Server started on xxx.xxx.xxx.xxx for:    ProfessionalEditionMCU
9:15:29 (metrowks) Wrong hostid on SERVER line for license file:
9:15:29 (metrowks)     C:\FLEXlm\license(10.4).dat
9:15:29 (metrowks) SERVER line says 3c79b2f7, hostid is 90e6ba605620
9:15:29 (metrowks) Invalid hostid on SERVER line
9:15:29 (metrowks) Disabling 1 license from feature ProfessionalEditionMCU(D92AF33EF19D)
3c79b2f7 is that servers disk serial and 90e6ba605620 is that servers MAC address.
I can't add the "DISK_SERIAL_NUM" qualifier as that causes the license "CRC" check to fail.
I opened a Service Request to no avail they seem to have stopped responding.
Is their any help to be had here?
965件の閲覧回数
trytohelp
It seems there is a problem under your Freescale account.
On my side I see the license registration FSL-147e-e051-3386-f1d0-915d-d6 which is for MCU v10.2.
However on your side this is not listed.
I've removed it.
Try again.
Now you should see MCU V10.3 in the list.
Pascal
5 返答(返信)
965件の閲覧回数
trytohelp
Hello Dave,
May be there is an issue in our web licensing system.
I've checked in our data base and found there are 2 registrations code associated to the 3C79B2F7 diskID.
Your registration is DLA-STD2PRO-FL and it is locked on DiskID 3C79B2F7.
Under this registration I see the license file for:
      CodeWarrior for Microcontrollers (Windows Hosted, Eclipse based) - Professional Edition V10.2
Strange ... I should see V10.3 and not V10.2.
Can I recommend you to:
      - rehost the registration on DiskID.
            This will re-initialize the license system. In some case a rehost could solve the problem.
      - reload the license file.
If this is not working, I propose you something else.
hope this will help you.
Pascal
965件の閲覧回数
DaveB
Pascal,
Thank you for your reply. I re-hosted  http://postimg.org/image/dm562eojv/ no problem.
But on the suite details page there is no list item for CW 10.3 for MCU http://postimg.org/image/ieftmpzvh/
How can I get the re-hosted license?
Thanks.
966件の閲覧回数
trytohelp
I've removed it.
Try again.
Pascal
965件の閲覧回数
DaveB
Pascal,
That worked. You've made my day.
Thanks very much.
965件の閲覧回数
trytohelp
Perfect.
Have a nice weekend
Pascal
