Sensor Toolbox&KwikStick
1,513 次查看
georgek
We want to use your MMA45xQ Sensor Toolbox and connect the sensor boards to the KwikStick board. Is it possible?
Thanks for your advice,
George
1,414 次查看
TomasVaverka
George,
Sensor toolbox sensor boards are not directly compatible with the TWRPI socket on the KwikStik board.
I would recommend using the TWRPI-MMA845XQ board that is compatible with the KwikStik board:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=TWRPI-MMA845XQ
I have also attached its schematic.
Tomas
1,415 次查看
TomasVaverka
George,
Tomas
1,414 次查看
georgek
Thanks for your prompt reply, Tomas! We will use the the TWRPI-MMA845XQ board.
George
