I'm currently using the MPX5100AP with 90degree bending the lead. The actual direction of the bending lead is the picture below.
I would like to know if there is risk of damage the wire bond to the die. If the lead can be bent to use, are there any carefully handle method when bending?
Thanks and regards,
SeungYong
