MMA8452QR1
MMA8452QR1
abialevich1
This chip has three ground pins 5, 10, and 12. Can I connect pin 5 and 12 to the ground and leave pin 10 ungrounded? Please advise.
diazmarin09
Hello abialevich1,
I hope all is great with you. Thank you for using the NXP communities.
I do not recommend leaving the pin 10 floating.
The GND pins are separated internally because these pins are used for factory calibration/compensation, however, all these pins need to be connected externally to GND.
I hope this information helps.
David
