Help: Distance Sensor
3,053件の閲覧回数
Apoorv_iitd
I am working on a micromouse. I need some Accurate Proximity Sensors. Could anyone help me out on this field.
タグ(1)
1,767件の閲覧回数
Joshevelle
Senior Contributor I
I would recommend you the MPR121, very low power: 29 μA supply current with 12 electrodes being monitored with 64 ms response time and IRQ enabled.
Proximity sensors are very small (3x3mm). If you want to accelerate the evaluation stage of your project I would highly recommend you to get the KITMPR121EVM: KITMPR121EVM Product Summary Page
Is a very low cost evaluation board for the MPR121 and you can test the device out of the box.
hope it helps =)
Josh
2 返答(返信)
1,768件の閲覧回数
Joshevelle
hope it helps =)
Josh
1,767件の閲覧回数
GrungeRey
Try MPR03X or MPR084 if needed more sensor.
