FXOS8700 & MAG3110 ground plane
939件の閲覧回数
eduardrazumovsk
Is there any information about ground planes regarding the sensors ?
What is preferable - separate sensor's ground plane from board's digital ground or the same digital ground plane for both ?
Eduard
ラベル(2)
タグ(1)
748件の閲覧回数
reyes
Hi Eduard,
You can use the same ground plane for both.
As an example, you can see that we use the same ground for both devices in our FRDM-FXS-MULTI in the following link: http://cache.freescale.com/files/sensors/doc/support_info/FRDM-FXS-MULTI-B.pdf
There is an application note with some layout recommendations for PCBs using Magnetometer sensors that I think could be useful for you in the following link: http://cache.freescale.com/files/sensors/doc/app_note/AN4247.pdf
Jose Reyes
