FXLS896xAF SDCD Simulator?
322 次查看
andrewneil
Is there any simulator/simulation available for the SDCD ?
So that captured data could be fed through it to allow "tuning" of the parameters?
Or 3rd-party datasets could be used ...
309 次查看
diazmarin09
Hello andrewneil
Once again, thank you for using the NXP community.
As far as I know, we do not have such tool. Please accept my apologies.
David
314 次查看
diazmarin09
Hello andrewneil,
I hope all is great with you. Thank you for using the NXP communities.
I assume that you have already reviewed the application note AN12004 which is very useful in regard with the SDCD block.
Have you considered using the FreeMASTER Sensor Tool?
FreeMASTER Sensor Tool is the sensor evaluation, data-visualization and application development software based on NXP FreeMASTER framework for IoT/Industrial/Medical sensors. It provides out-of-box sensor demonstration GUIs for quick sensor evaluation and development framework for end users to extend/create their custom applications.
Is that what you are looking for?
David
312 次查看
andrewneil
No - that seems to just work with live data from the sensor itself?
Looking for something that could be fed with pre-captured data.
310 次查看
diazmarin09
Hello andrewneil
David
