Can FRDM-K64F and FRDM-FXS-MULTI2-B be combined to work?
887 次查看
qiuhai
Hello supporters. I am a beginner to use the development board. I purchased one FRDM-K64F and one FRDM-FXS-MULTI-B. Can these two boards work together?  From the software of Freescale Sensor Fusion Toolbox, it is possible to choose the FRDM-FXS-MULTI-B under the FRDM-K64F.  If possible, can you provide me some guideline to use them.
In my case, I want to use the board to collect the data. It does not work at all in the Freescale Sensor Fusion Toolbox. Can you provide more instructions to make it work on the software of Freescale Sensor Fusion Toolbox?
标记 (2)
585 次查看
michaelestanley
Hai Qiu,
Yes it can work.  From your question, I am assuming you have not downloaded the sensor fusion development kit from nxp.com/sensorfusion.  Most of your questions should be answered in the user guide included in that software distribution.  If you've already downloaded the sensor fusion toolbox, you can use the File->Flash function to program your board.  Check the "Record" checkbox on the "Main" tab of the GUI to start data logging.
Mike
