Dear NXP support team,
I would like to use ISO7816 interface in SE050.
(i) Can the following environment use ISO7816 interface?
- EdgeLock® SE050 Development Kit
- SE050C2 chip
(ii) If answer of (i) is "yes", would you tell me what document should I refer to in order to use ISO7816 interface?
Masahiro Marume
解決済! 解決策の投稿を見る。
Hi @masa_m ,
Actually this kind of interface is just available with some custom type of SE050. You have to contact your local NXP Marketing/sales or local FAE for further help.
Kan
Hi @masa_m ,
I am sorry, but this kind of interface is not supported in the following environment:
- SE050C2 chip
Only the following interfaces are available.
Hope that makes sense,
Kan
Hi Kan,
Thank you for your response.
Would you tell me which environment supports ISO7816 interface?
I found the following description in SE050 datasheet
So, I thought SE050 can use ISO7816 interface.
Masahiro Marume
Hi @masa_m ,
Kan
