Does the EdgeLock SE050 Plug & Trust middleware support non NXP MCU / MPU boards?
1,641 次查看
jordijofrenxp
The EdgeLock SE050 Plug & Trust middleware comes with pre-built support for many NXP MCU / MPU boards. However, you can also leverage SE050 Plug & Trust middleware if you are using any other MCU / MPU board.
From an HW perspective, you can use the OM-SE050ARD evaluation board to connect your board via the Arduino connectors or the external I2C connector.
From an SW perspective, The EdgeLock SE050 Plug & Trust middleware has been designed to facilitate portability to multiple platforms and OS. For more information about how to port the middleware, you can refer to AN12448 SE050 Plug & Trust middleware porting guidelines.
标记 (1)
653 次查看
rodolfoveltrigo
Hi all,
this is the new NXP weblink of this application note (old link does not work anymore).
https://www.nxp.com/docs/en/application-note/AN12448.pdf
Cheers
Rodolfo
