Yocto S32V Kernel Panic
1,797件の閲覧回数
hennadiyyatskov
We are currently building the BSP 15 for the S32V. The Yocto build is successfull and we can boot from the generated image. However during boot, we get a kernel panic, the init script simply fails with an error (-2).
I've attached the latest bootlog, were I tried to start init directly using init=/sbin/init.sysvinit, sadly the result is the same as for init=/sbin/init
1,445件の閲覧回数
KushalShahNXP
Hi Hennadiy,
Did you used correct components from the Yocto build? I mean u-boot, dtb file, rootfs, image.
Please use the latest BSP available (now v16.1) and try again.
Kushal
