I downloaded the tresos Studio 23.0 software on the NXP official website. The official website provides an activation code that shows that it can be used until March 30, 2021. However, when I activate, it always prompts that the server cannot be connected. I don't know what caused this. I am using S32K144 MCU
Err:
INFO: Trusted Storage initialization done.
Manual Node-Locked License Activation processing ...
ERROR: Processing response (50019,41200,10246)
Activating NodeLocked License XXXX-XXXX-2960-3980, Number Of Licenses: 1
Status: 4, Creating request
Status: 5, Request created
Status: 6, Context created
Status: 0, Error
ERROR: flxActAppActivationSend (50041,41143,34)
Connection to FlexNet Operations Server failed.
Status: 0, Error
Status: 0, Error
Another way is you can try with Offline activation. Click to "Create Activation Request", then save the activation request file. Access to https://www.elektrobit.com/support/licensing/ then follow the instruction.
Nam
I will try what you said, thank you very much
Dear ywjack,
From the error message, we can see that "Connection to FlexNet Operations Server failed". Then could you please check your internet connection. I still can use the your activation code normally.
Could you please also share the "Elektrobit Client License Administration" 's version which you are using.
Hung.
Hi :hungnguyenphi
The version I use is 1.2.4, I also try to use other versions to activate the phenomenon is the same as shown below
Thank you
Is your problem solved? I also encountered the same problem, how can I activate it successfully?
Hello ywjack,
I also try to check the activation code with the version 1.2.4 and it still work. Then I am pretty sure that you have some issue with the internet connection. Could you please help to check with your company 's IT.
Hung
