s32k31x recovery Mode
901件の閲覧回数
hagoo
hello,
I disabled recovery Mode in S32k31x.
After generating DES once and T32 was attached, THEN S32k31x runs an infinite loop at 2040012C
That is the address value when entering recovery mode.
Do you know why it stays at that address value even after disabling the recovery mode?
If you check DCM_GPR_DCMRWP1 when s32k31x stay at that address value, you can see that it is disabled in C.
3 返答(返信)
864件の閲覧回数
lukaszadrapa
Hi @hagoo
that's strange, I can see no problem on my side.
When I didn't disabled the recovery mode, I reached the endless loop after 8 functional resets which were generated by code. When I disabled the recovery mode, I can trigger more functional resets, no recovery mode is entered:
After destructive reset (POR), the application is still working.
Lukas
752件の閲覧回数
jtpark
Hi Lukas,
Would you please let me know how to disable the recovery mode in software?
I am not able to find how to disable of DCM.DCMRWP1.
739件の閲覧回数
jtpark
Hi Lukas,
I found it.
