Hi Daniel,
Thanks for the response , YOU MENTIONED THAT THE PIN STAE IS RETAINED IN VLPS MODE also
Just to make sure I got this if an output pin is high before entering VLPS , it'll remain high while in VLPS mode.
Is that correct?
one more question,
Is THE LPIT TIMER clocked by LPO, functional in VLPR mode ? I know it is in VLPS and we use it for periodic wake up, but how the about VLPR mode?
There is this Excel sheet called S32K1xx_ Power_Mode_Configuration (Please see the attachment)that mentions enabled case1/2 .what does that mean?
Koorosh
Hi Koorosh,
1.
Yes, it will remain high in VLPS.
2.
Yes, LPIT clocked by LPO is fully-functional in VLPR.
3.
In the S32K1xx DS rev.12, Table 13, there are some specifications of the S32K1xx power consumption at certain conditions which are specified excel sheet.
