mex file not opening.
502 次查看
Mohit_Manvar
Hello experts,
I downloaded application note workspace from forum. I'm using S32D32 v3.4 IDE.
upon opening .mex file it is giving following error.
I also tried to import example in v3.5 and installed RTD driver version 3.0.0 but it is not opening.
please suggest me which IDE need to be used and which support package need to install. if possible, please provide link for download directives.
Application note link: Link
regards,
Mohit
487 次查看
VaneB
Hi @Mohit_Manvar
The example code was created using S32DS 3.5 and RTD version 3.0.0  P01 Hotfix02. To open the project please make sure to have installed the S32K3 development package and the same RTD version of the most recent releases of RTD 3.0.0 like the P07.
B.R.
VaneB
475 次查看
Mohit_Manvar
I'm trying to install S32K3xx development packages but giving following error.
kindly provide solution or link from where I can download directly and install externally.
Mohit Manvar
466 次查看
VaneB
Hi @Mohit_Manvar
Check the following posts. There is discussed this topic, it might be useful for you.
S32K3xx development package installation problem
S32K3xx development package could not be installed
