measure current in S32K148 tc10 sleep mode
343件の閲覧回数
mhjo
I want to measure the current when S32K148 in tc10 sleep mode
I used SDK named phy_tja1103_s32k148 and I can see change state via LED of S32K148
then, I tried to measure the current via J19 (I already removed R59) referencing below
https://community.nxp.com/t5/S32K/how-to-the-put-the-S32k148-EVB-into-sleep-mode/td-p/1233592
but the current of wakeup mode is about 49.5mA and the current of sleep mode is about 47.5mA.
I think it's not reasonable data
but when I tried to measure the current with VLPS & HSRUN & RUN mode, I can see reasonable data
What is difference between TC10 Sleep mode and VLPS mode?
and How can I get reasonable current data in TC10 sleep/wakeup?
タグ(3)
28件の閲覧回数
Fidel
Hello, I saw you mentioned " SDK named phy_tja1103_s32k148 ", where did you get it ? and would you please help to share it ?thanks a lot~
