how to measure the 16Khz frequency PWM signal in S32k144??
1,121 次查看
mogilipuri_harish
hello team,
we are using S32K144 uC in our designs. which pins can measure the PWM 16kHz signal in micro controller. can you please provide the pins details and information.
5 回复数
1,112 次查看
Senlent
Hi@mogilipuri_harish
you can find the pinout of FTM in the picture below.
1,109 次查看
mogilipuri_harish
all pins will support for measuring the 16khz frequency PWM
1,103 次查看
Senlent
I thought you were using FTM module to measure input signal.
Usually we use FTM input capture feature to measure input signal, please take a look at the demo  "ftm_signal_measurement_s32k144"  we provided in your IDE.
1,094 次查看
mogilipuri_harish
can you please hardware application note
1,089 次查看
Senlent
I don't quite understand your question,what kind of application note do you need?
you can find all appliation note related to S32K1 in the link below.
https://www.nxp.com/products/processors-and-microcontrollers/s32-automotive-platform/s32k-auto-gener...
