Unable to enter stop1 mode with WFE
755件の閲覧回数
zxc1
I would like to know if the S32K144 supports the wfe instruction to go to low power?
I tried to call power_sys_setmode() and replace the WFI instruction in there with WFE instruction, but cpu can't go to STOP1.
700件の閲覧回数
VaneB
Hi @zxc1
The S32K1xx RM specifies the following stop modes STOP1, STOP2, and VLPS with the WFI instruction only.
The system functionality with the WFE instruction is not specified and should not be used.
3 返答(返信)
735件の閲覧回数
VaneB
Hi @zxc1
The "SEV" and "WFE" are usually used on multi-core systems.
Although these instructions are included in the S32K14x, s this technology is a single core, so they should not be implemented in the application code.
There is an application note that could help you with the power modes.
Power Management for S32K1xx
B.R.
VaneB
712件の閲覧回数
zxc1
Hi,@VaneB
So "WFE" is able to enter STOP1, but I shouldn't be able to use it in the application code, right?
701件の閲覧回数
VaneB
Hi @zxc1
