The dual cores enable the same CAN channel to transmit and receive data at the same time
245件の閲覧回数
ALXY_WANG1
I am using the S32K358 development board to debug the dual-core function, and I am currently checking whether the two cores can use the same CAN channel to send and receive data at the same time, and if so, whether the initialization process of both cores needs to be initialized by the CAN channel, and the specific initialization process is different from that used by a single core
3 返答(返信)
195件の閲覧回数
Senlent
Hi@ALEX_WANG1
Both cores can access and operate the FlexCAN module, but you should avoid having two cores operate the same peripheral. Usually you need to define which core needs to access which peripheral resources at the beginning of the design.
190件の閲覧回数
ALXY_WANG1
Can't two similar cores simultaneously enable the CAN0 channel
181件の閲覧回数
Senlent
Hi@ALXY_WANG1
I have replied to you before.
All cores of S32K358 can access the core operation CAN0 module, but you should avoid multiple cores accessing the same peripheral at the same time.
