Signal is not carried by any frame in lin stack communication.
1,600 次查看
skb
Hi everybody.
recently, I test lin communication.
I receive LDF file, when I change ldf file and reloading,
some error is occured.
only name error is shown.
how can i solve this problem?
thanks
标记 (4)
1,569 次查看
PetrS
as mentioned in previous thread...
The Lin protocol will communicate by transferring frame in the bus. Each frame will contain one or more signal. So if one signal which is not a part of any frame in the LDF, then it should not be exist in the LDF file(should be removed from LDF file).
BR, Petr
1,570 次查看
PetrS
BR, Petr
1,553 次查看
skb
Hi, @PetrS
thank you relply, that problem was solved!
