The pop up window comes, when I try to generate code .
I'm am using DS32 ARM 2.2
pop when try to generate code
Also not able to add module to projectwhen try to add module no option is not enable
Solved! Go to Solution.
Seems that your project is baremetal without SDK included. Please refer to the Attaching an SDK to an existing project of S32DS_ARM_User_Guide.pdf.
Please select the SDKs next time you create a new project.
Robin
Thanks for your reply @Robin_Shen,
i was following same procedure.
my issue is solved. ,,some packages are not added.
Robin
