Does anyone have an example of CAN with extended ID ?
There is no big difference with respect of configuring the MB for standard ID.
Within a MB you need to set the IDE bit and set full 29-bit ID field. Moreover, for TX MB the SRR bit has to be set too.
BR, Petr
