S32K344 GMAC sends abnormal data
274 次查看
songoku711
I am bringing up automotive ethernet using my custom development board that included S32K344 and TJA1101A transceiver working in MII mode. I used example from S32K3 lwip package to bring-up, with some modification to adapt with MII interface. So far, it managed to establish link-up, but it sent abnormal data throughout communication, I mean like this captured picture, the sent data are all zeros.
The strange thing is that, when I plugged in my debugger to debug, and set breakpoint at gmac transmit function (e.g. gmacif_low_level_output) and start running, then for each time the program stopped at that function, I clicked continuing to run, and I saw that the data packets sent out were correct.
Also this issue only happened at transmit direction (S32K3 sent data to PC), for reception it seemed working normally, because I checked packet data in wireshark with data in memory dump and they are the same.
I attached the zipped project code, and above captured packet logs. Hope you guy can check it and help me.
Thank you in advance.
标记 (3)
220 次查看
PetrS
it could be something with cache, I think. Maybe tx data buffer is not placed in non cacheable area.
Try to disable data cache at all, so remove D_CACHE_ENABLE in preprocessor setting, if it makes difference.
BR, Petr
239 次查看
songoku711
Can anyone help me here?
221 次查看
PetrS
BR, Petr
210 次查看
songoku711
Thanks, Petr.
I disabled CACHE support in Cache_Ip, also deleted macro D_CACHE_ENABLE in pre-processor setting, and it worked.
One more question, how can I place TX data buffer in non-cacheable area, so as to keep enabling cache support for future purpose?
