hello,
What are the regions that cannot be accessed?
Flash address 0x600000
Have you installed the HSE_FW?
I will confirm this and reply later; What will happen if this installation or not installation occurs?
What status error do the APIs return?
This is reading the saved IMU calibration parameters from memory, and once read, the code crashes; Because a watchdog was used externally, it has been constantly resetting.
