S32K311 HSE FW CAN NOT INSTALL BY MU
zhengjianfei1
Hi NXP,
We found K311 some problems as below,could you give me some suggestions,Thanks!
Question1: We found that S32K311 HSE CLOCK cannot be 120MHZ. It does not conform to manual specifications as picture bellow.
Question 2:S32K311 CAN NOT install HSE FW by MU. It can be ok in S32K312.We found SBAF can install ok ,but FW can not run.please see picture bellow.  I think it may be caused by 120M HSE clock.
Tags (3)
OliverTian
Hi, Jianfei
    Currently, no tested on such scenario on S32K311 chip and please use sBAF to install HSE FW.
    How about change HSE clock to 60MHz?
zhengjianfei1
Hi Oliver,
   Thanks for your suggestion. We finally found FW installating can be OK with following clock configuration.
