S32K3 HSE DCACHE
S32K3 HSE DCACHE
1,107 次查看
longfeiwang
Does AB swap not support applications that enable cache?When Hse switched partition functions(AB swap), I found that as long as I open the Dcache, the interface functions could not run. It will run if I close the Dcache
1,092 次查看
petervlna
I can give you answer, but not here on public community.
Secure questions are always supported via tickets.
Please submit a new query on NXP web:
https://community.nxp.com/t5/HomeTest-Knowledge-Base/How-to-submit-a-new-question-for-NXP-Support/ta...
Peter
1,093 次查看
petervlna
Peter
645 次查看
CarlOfVmax
I cannot access your linker, but I can access some secure files aready. How can I get access right of your linker. Thank you!
