Does AB swap not support applications that enable cache?When Hse switched partition functions(AB swap), I found that as long as I open the Dcache, the interface functions could not run. It will run if I close the Dcache
Solved! Go to Solution.
I can give you answer, but not here on public community.
Secure questions are always supported via tickets.
Please submit a new query on NXP web:
Peter
Peter
I cannot access your linker, but I can access some secure files aready. How can I get access right of your linker. Thank you!
