When i installed mcal of "S32K14X_MCAL_4.2_RTM_HF3_1.0.1" , i downloaded license file from nxp and seems the license is vaild. then i loaded this license, will report errors of "Feature AUTOSAR_MCAL_S32K14x version 4.2 is required".
i had tried many methods to solve this error, but always can't work, so if anyone met the same problem, pls give me a reply, many thanks
This seems like an issue with license. I have just tried it and successfully installed it on my PC.
There is no issue. From your screenshot I see the license file you selected is apparently not right one.
Please try to generate license one more time from license tab show above.
Peter
hello Peter, thanks a lot for your reply, but i have checked again for the license generation process
then i pressed the button of "Save all", i get the file named "license.dat", but when i installed the Mcal, still the problem appeared again
So, i'm very confused now
I see you license is not same as mine. Strange.
Here is how it looks for me, and the license is working:
Please try to download the license associated with the SW package you have.
You can try doing the whole installation and license generation once again. To be sure you are generating correct license for correct product.
As I do not see any issue here on our side.
Peter
Have you solved it? I encountered the same problem
