generate GMAC of IVT return HSE_SRV_RSP_INVALID_PARAM
zh8538
I try to generate GMAC of IVT, but return HSE_SRV_RSP_INVALID_PARAM,
Please help analyze the reason, thank you very much
Tags (3)
lukaszadrapa
Hi @zh8538
did you check if those defined values (IVT etc...) match your project? Did you try to disable data cache memory? All the data structures and variables used for communication with HSE via MU must be forced to non-cacheable region.
Lukas
