S32K146 RTC
S32K146 RTC
2,685 次查看
Jeevi
I am trying S32K146 microcontroller with external RTC through I2C communication. Is there any examples related to it?
2,655 次查看
Senlent
Hi@Jeevi
I can't help you check the RX3180 related tests because this is not within the scope of our service.
I suggest you use a logic analyzer or oscilloscope to analyze whether the data you are generating and receiving is correct
2,665 次查看
Senlent
Hi@Jeevi
1. There are routines about I2C in the IDE. These routines can help you become familiar with how to use the I2C module of S32K1.
2. We do not have usage routines based on S32K1xx communicating RTC chip through I2C
2,660 次查看
Jeevi
Hi @Senlent
Thanks for the information. I have modified the code of S32k146 lpi2c master with external RTC module. Can you please verify the code.I am not able to get the RTC value from the module. I have attached the main.c file and registers file. Can you please help me?
2,656 次查看
Senlent
Hi@Jeevi
