hi engineer
i do not find the demo about LVD in SDK. I donot know how to code to enable the LVD function.could you help me? thank you advance.
Solved! Go to Solution.
It is not implemented in the SDK drivers.
If you just want to reset the MCU when VDD drops below the V_VLD threshold, you need to set the LVDRE bit.
If you need an interrupt instead of the reset.
A simple example is attached.
BR, Daniel
BR, Daniel
thank you Daniel, it can work in my project.
i want use this function to store some important data in mcu flash.
