hello Dears , S32K144 demo compiled fail in s32ds . I create a S32K project from example. but can not built successfully. problem like below . ( tips : i created some s32k project in S32DS , but suddenly I can not build successfully in my computer . it's so wired. )
have you generate the code before, if not ,try generating the code by clicking the button shown in the picture below.
yes , Senlent. I had generated the PE code before compile.
this project I could compile successfullu before. I made it as a zip file . I can be sure it could be compiled before. but until that day ,sudenlly i could not .
and in the end , I uninstall the S32DS , and install it again. then I can compile this project again.
thanks for your reply. thanks all the same.
