S32K144 TXERRCNT and RXERRCNT
Beautr
Do the TXERRCNT and RXERRCNT of the S32K144 CAN controller count automatically? Do we need code for any Settings?
Senlent
Hi@Beautr
No, the count is automatically incremented if an error is encountered during normal operation
Beautr
When will the S32K144 go into freeze mode?
Senlent
Hi@Beautr
For flexcan module, lot of registers can only be read/write on Freeze mode.
for example,
Therefore, if you need to change the Flexcan reigster during normal operation, you should first see if you need to go into freeze mode.
Beautr
Hi, Senlent
    Thank you for your reply. I have one more question.
Are send and receive error counters automatically counted according to CAN2.0B specifications? Do we need code for any Settings?
Senlent
Hi@Beautr
