S32K144 Reset Issue
S32K144 Reset Issue
991件の閲覧回数
AbhishekK
Hello ,
 I will explain you the scenario from starting ,so it will be easy to under stand my problem.
I am trying to run S32k144_Hello_clock  example project using S32DS ,but I am facing error like below ,
  The red LED is continuously ON and the two green LEDs are also ON.  I'm able to detect the board on my computer .I don't see any output -blinking the LED
so for resolve this issue I followed this Post :
Re: NXP S32K144 EVB Reset LED continuously ON - NXP Community
In this post same issue mentioned so I tried first Solution provided by Nxp NXP TechSupport Robin_Sen . but It wont work .
As I have seen another post to resolve this issue :
Solved: NXP S32K144 Red LED Continuously ON - NXP Community
so in this post their is suggestion given is as below :
****USE the RappID bootloader way of flashing the board. ****
so I want to  try this method but I am not able to understand this method . this is the issue .have you  understand my issue ?
For this RAppId Bootloader  posted one post :RAppID Bootloader rbf file for S32K144W - NXP Community
I have seen their are 2 files attached in it ,
S32K144W_S32DS_UART1_CAN0.zip
in this pdf you have mentioned release content . Where I can find this release content ? I want to see that images for Hardware Connection and all.
Abhishek
タグ(1)
6 返答(返信)
838件の閲覧回数
AbhishekK
Hello Robin
I have downloaded it .and I have fallowed process in it. but still not able to do it .I will share process I have followed .so it will be easy to get resolve this issue.
819件の閲覧回数
Robin_Shen
Please check the value of MDM_AP status and control register by refer to https://community.nxp.com/t5/S32K/Unbricking-S32K146/m-p/937227
Do you have CSEc enabled? Or have you ever run the CSEc example in AN5413SW or S32K1 SDK or RTD?
If so, please refer to the 3.2.5.2 Mass erase and CSEc considerations of AN12130 Production Flash Programming Best Practices for S32K1xx MCUs.
If not, then I'm afraid you'll have to replace a new S32K144 chip by soldering or buy a new S32K144EVB.
925件の閲覧回数
AbhishekK
Hello Robin,
Can you please help me with process mentioned in below post ?
I am trying this process but not able to understand. Where is it going wrong?
857件の閲覧回数
Robin_Shen
Sorry for the delay.
Did you download the RAppID Boot Loader Utility? After install it, the RAppidBL_UserManual.pdf can be found it's folder.
926件の閲覧回数
AbhishekK
I have tried but it is not helpful .means problem is not resolved
973件の閲覧回数
Robin_Shen
Hi Abhishek,
Do you mean the two Green LED D2(SDA_LED_R) and D3(PWR_LED) are light? Then I think the OpenSDA and VDD of S32K144 are OK.
Please Enter OpenSDA Bootloader Mode and then click SDA_INFO.HTML check the Application Version. If Application Version is: 1.19 (ok). Here is the information of my board: id="BOOTVER" value="1.13" id="APPVER" value="1.19".
Then you can try to drop srec file to EVB-S32K144. I have attached hello_world_s32k144.srec for you to test. The RGB leds should be able to blink.
The Jumper setting of S32K144EVB: J107 2-3 J104 1-2. Connect the USB cable to a PC using a USB cable and connect other end of USB cable (microUSB) to mini-B port on to J7 on your S32K144EVB.
Robin
