S32K144: FlexRAM as Emulated EEPROM Initial Values?
2,878件の閲覧回数
mahmoudsherrah
I succeeded in configuring FlexRAM as emulated EEPROM and it is working as expected. I only wanted to know how to set initial values in this EEPROM.
I tried to do the following (struct initialization):
typedef struct
      uint8_t u8;
      uin16_t u16;
} eeerom_data_t;
__attribute__ ((section(".eeeprom"))) eeerom_data_t eeerom_data = {.u8 = 12, .u16 = 3456};
But unfortunately didn't work, I think because the FlexRAM area is set to 1's on flashing the software to S32K144.
Is there any way to achieve initial values of FlexRAM as emulated EEPROM? Thanks
2,075件の閲覧回数
danielmartynek
The system should not access the data in FlexRAM until the flash controller completes the initialization indicated by the FCNFG[EEERDY] flag.
If you need to have the EEPROM initialized, copy the data from Flash once the EEPROM is ready.
4 返答(返信)
2,076件の閲覧回数
danielmartynek
2,075件の閲覧回数
mahmoudsherrah
Unfortunately, this wastes program memory but I assume it's not that big of an issue. I also think this is the only way to do it. Thanks anyway.
2,075件の閲覧回数
danielmartynek
In AN12130, there is:
If your programmer/debugger supports scripting, you can use a script to check the EEERDY flag and to write the data.
But this is not a question on the MCU but rather on the programmer.
2,075件の閲覧回数
mahmoudsherrah
Thanks for the link. It's interesting but as you said it is programmer work not SW. I think copying from flash to FlexRAM after EEERDY does the trick.
