S32K144 Bootloader demo with PLL could not work
KILLERzheng
I get the demo from unified bootloader framework, but it could not work with the PLL enable, and when the project init clock, it goes to hardware error. On the other hand, if I set the PLL false, it could works. I do not know where the error is. Besides the EXTAL of my board is 16MHz, is there any wrong with the hardware designing?
Tags (2)
Senlent
try this configuration.
Senlent
Hi@KILLERzheng
This routine uses an 8M external clock crystal oscillator by default. If you use a 16M crystal oscillator, there will be problems. You need to change the clock configuration, or replace the crystal oscillator with 8M. If you don't change the crystal oscillator, you have to change the configuration of the clock part of the BT and APP routines.
KILLERzheng
Hi Senlent,
Thanks for you response.
I have not been familiar with PLL configuration, could you please give me some suggestions that how to configure with it?
Senlent
KILLERzheng
Do you mean that way to modify the configuration?
Senlent
Hi@KILLERzheng
yes, please have a try.
