I am using S32K144.
I want to read a binary file, but when I try to read the file with the fopen function, it returns NULL.
Is it possible to read binary files with S32K144? If so, could you please give me an example?
KK2
it would be necessary to implement file system. Otherwise the fopen cannot be used. We do not have such example.
Not sure what is your goal but common way is to link a bin file to your project as described here:
And then you can access the bin file directly without fopen function and without file system.
Lukas
