S32K118 adc_hwtrigger compil problem
851 次查看
zhaowei961
This interface will pop up when compiling ADC module. The file causing the problem was not found in this path.Compilation failed,whar's the problem?need help.Thank you.5.png
标记 (2)
783 次查看
Alexis_A
Hi zh ew,
I have tried the example you mention and couldn't find this error, remember that after importing the project you need to press the processor expert generator code.
Let me know if this helps you.
Alexis Andalon
783 次查看
zhaowei961
Thank you very much. I found the answer. The problem is caused by encryption software
