FS32K118LFT0MLHR is the material model used in our current BMS products. For the current SOT1699-1: LQFP64 packaged product, all four corners of the chip purchased by the agent have exposed copper wires, similar to a pin being cut. Is this normal? Is there a detailed process description corresponding to this LQFP? What are the risks in product design? I look forward to your reply. Thanks a Lot !
Solved! Go to Solution.
Hi @zhangzhiyong,
This is normal, this is a part of the lead-frame that is used to support the chip during the assembly.
You can search for lead-frame on the internet.
This is an x-ray picture of an MCU (not S32K)
Hi @zhangzhiyong,
