S32K FlexNVM
S32K FlexNVM
2,009 次查看
wanglijun
I have aquestion about the flexnvm, if FlexNvM is used as progrmaming flash, and need to support FBL flashing. Is there some issue? Is there some points need to be cared?
Thank  you!
标记 (1)
7 回复数
1,999 次查看
danielmartynek
You can refer to AN12218 S32K1xx Bootloader
https://www.nxp.com/docs/en/application-note/AN12218.pdf
https://www.nxp.com/docs/en/application-note-software/AN12218SW.zip
The bootloader is placed in FlexNVM.
The FlexNVM can be used for code if is partitioned for DFlash.
1,988 次查看
wanglijun
If FlexNvM is partitioned to PFLASH, and this section is application. Is it ok to download by FBL?
Thank you!
1,976 次查看
danielmartynek
Hello @wanglijun,
The FlexNVM memory can be partitioned as DFlash not PFlash.
But you can use DFlash for the code.
1,969 次查看
wanglijun
Hello Daniel,
If using DFLASH for the code, and the section is for the application, is it ok to download by FBL?
Thank you!
1,954 次查看
danielmartynek
Hello @wanglijun,
Yes, you can use DFlash for an application loaded by a bootloader,
1,941 次查看
wanglijun
Ok.
Another question, if it is ok one part of FlexNvM is DFLASH, another part used as PFLASH?
Thank you!
标记 (1)
1,929 次查看
danielmartynek
Hello @wanglijun,
FlexNVM can't be used as PFlash.
It can be partitioned as Emulated EEPROM or DFlash or split between the two.
But DFlash can be used for the application code.
