Regarding for .Hex file generation of S32DSK342
498 次查看
Pragadeesh
I am working on s32k3k42 driver module configuration, in that RTD package have EB tresos example folders , if I take any of the example project, I can able to generate only .elf file of project.
Current run.cmm and device.cmm file in debug folder is supporting only for generate the .elf
So that ,I need corresponding run.cmm or device.cmm file script which will support to generate and load .hex file
And also I need to know how to modify make file for generating .hex
Please help me for proceeding further.
Thanks & Regards,
Pragadeesh.
479 次查看
davidtosenovjan
S32DS can create HEX file directly, here you may find a procedure:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Generate-S-Record-Intel-HEX-Bina...
